13 years agoPost NIOS Build Error with QSYS
Hi all,
I have generated my QSYS system successfully and I build my NIOS program using the generated .sopcinfo file. After I build my NIOS code and successfully update the .hex file, I attempt to re-generate the QSYS system, but this fails saying that it failed to generate my on-board memory module. Any thoughts? Thanks, Zahi Hakim1 Reply
that's very strange. i don't think Qsys should look at any software during generation
are you sure you haven't changed anything in the system? can you back up the Nios code and purge, then regenerate?
