12 years agoPorting DE_NET2 to NIOSII running on Quartus 12.1sp1 and QSYS
I'm trying to port DE_NET2 to Quartus 12.1sp1 and QSYS. I have created in QSYS dm9000a component based on DM9000A_IF.v file. The code:
module DM9000A_IF( // HOST Side
iDATA,
oDATA,
iCMD,
iRD_N,
iWR_N,
iCS_N,
iRST_N,
iCLK,
iOSC_50,
oINT,
// DM9000A Side
ENET_DATA,
ENET_CMD,
ENET_RD_N,
ENET_WR_N,
ENET_CS_N,
ENET_RST_N,
ENET_INT,
ENET_CLK );
// HOST Side
input iDATA;
input iCMD;
input iRD_N;
input iWR_N;
input iCS_N;
input iRST_N;
input iCLK;
input iOSC_50;
output oDATA;
output oINT;
// DM9000A Side
inout ENET_DATA;
output ENET_CMD;
output ENET_RD_N;
output ENET_WR_N;
output ENET_CS_N;
output ENET_RST_N;
output ENET_CLK;
input ENET_INT;
reg TMP_DATA;
reg ENET_CMD;
reg ENET_RD_N;
reg ENET_WR_N;
reg ENET_CS_N;
reg ENET_CLK;
reg oDATA;
reg oINT;
assign ENET_DATA = ENET_WR_N ? 16'hzzzz : TMP_DATA;
always@(posedge iCLK or negedge iRST_N)
begin
if(!iRST_N)
begin
TMP_DATA <= 0;
ENET_CMD <= 0;
ENET_RD_N <= 1;
ENET_WR_N <= 1;
ENET_CS_N <= 1;
oDATA <= 0;
oINT <= 0;
end
else
begin
oDATA <= ENET_DATA;
oINT <= ENET_INT;
TMP_DATA <= iDATA;
ENET_CMD <= iCMD;
ENET_CS_N <= iCS_N;
ENET_RD_N <= iRD_N;
ENET_WR_N <= iWR_N;
end
end
always@(posedge iOSC_50)
ENET_CLK <= ~ENET_CLK;
assign ENET_RST_N = iRST_N;
endmodule
Here's the componet overview: https://www.alteraforum.com/forum/attachment.php?attachmentid=8694 Timing was taken from old DM9000A class.ptf. Based on those settings I get in signal tap this results: https://www.alteraforum.com/forum/attachment.php?attachmentid=8695 when executing this code on NIOS: # define IO_addr 0# define IO_data 1
iow(0x1E, 0x01);
void iow(unsigned int reg, unsigned int data)
IOWR(DM9000A_BASE,IO_addr,reg);
usleep(STD_DELAY);
IOWR(DM9000A_BASE,IO_data,data);
Value of reg 0x1E goes to the bus. Also CMD going up was rather strange. So in the second try I have changed address units WORD to SYMBOLS in my component. And here's the result: https://www.alteraforum.com/forum/attachment.php?attachmentid=8696 Now I can even write the whole 16 bits at once, and CMD is gone. I suppose that it's not good that I get two 16 bit writes to the DM9000a. Perhaps it's related to the 32 bits that gets written by NIOS so it gives two clock cycles. I have provided only 16 bits, rest all zero. So my questions are: 1) How to make only one 16 bit write ? 2) The second IOWR(DM9000A_BASE,IO_data,data) - so writing the data (CMD should be high) never goes to the bus, CMD is always low. Any ideas why ? https://www.alteraforum.com/forum/attachment.php?attachmentid=8697 I add DM9000A_hw.tcl packed in zip, so you can easily open it in QSYS and see my component. Also I have uploaded the whole project to Dropbox: https://www.dropbox.com/s/6ru77wyptaxcfdc/fpga_imgproc.rar Thanks in advance, Best regards, madness3 Replies
I was able to make it running. I have made no changes to NIOS code except changing this define:
Also in the code the DM9000A.C file was included, which is rather bad so I only included .h file and had to move ether_addr table to .C file from .h. In my DM9000A component i have changed iDATA and oDATA to 32 bit and simply assigned lower 16 bits to ENET_DATA. I also resized iCMD to 8 bits and found out that bit 4 goes up when I write. So i simply assigned this bit to ENET_CMD. Also I changed read wait and write wait to 3 clock cycles in my DM9000A component (it's related to 100MHz clock for NIOS). Best, madness#define IO_data 4 - Altera_Forum
--- Quote Start --- Hi, I was able to make it running. I have made no changes to NIOS code except changing this define:
Also in the code the DM9000A.C file was included, which is rather bad so I only included .h file and had to move ether_addr table to .C file from .h. In my DM9000A component i have changed iDATA and oDATA to 32 bit and simply assigned lower 16 bits to ENET_DATA. I also resized iCMD to 8 bits and found out that bit 4 goes up when I write. So i simply assigned this bit to ENET_CMD. Also I changed read wait and write wait to 3 clock cycles in my DM9000A component (it's related to 100MHz clock for NIOS). Best, madness --- Quote End --- Is it true that regardless of the actual PHY chip, the mdio interface is common, and the device specific initialization is done in software? If so, couldn't an existing built-in qsys component (ex. LAN91C111) be instantiated, but registers initialized for the DM9000A? EDIT: Since these chips have MACs built-in to them, why is another MAC (Altera's TSE) added into the system design... how does that even work?#define IO_data 4 - Altera_Forum
--- Quote Start --- Is it true that regardless of the actual PHY chip, the mdio interface is common, and the device specific initialization is done in software? If so, couldn't an existing built-in qsys component (ex. LAN91C111) be instantiated, but registers initialized for the DM9000A? EDIT: Since these chips have MACs built-in to them, why is another MAC (Altera's TSE) added into the system design... how does that even work? --- Quote End --- Hi happy, Where can I find LAN91C111 qsys component ? Is it ported to new quartus version ? Your statement about mdio does make sens. I don't see Altera TSE mac in the design that I posted. Best, madness
