12 years agoPorting DE_NET2 to NIOSII running on Quartus 12.1sp1 and QSYS
Hi, I'm trying to port DE_NET2 to Quartus 12.1sp1 and QSYS. I have created in QSYS dm9000a component based on DM9000A_IF.v file. The code:
module DM9000A_IF( // HOST Side
12 years ago --- Quote Start --- Hi, I was able to make it running. I have made no changes to NIOS code except changing this define:
#define IO_data 4 Also in the code the DM9000A.C file was included, which is rather bad so I only included .h file and had to move ether_addr table to .C file from .h. In my DM9000A component i have changed iDATA and oDATA to 32 bit and simply assigned lower 16 bits to ENET_DATA. I also resized iCMD to 8 bits and found out that bit 4 goes up when I write. So i simply assigned this bit to ENET_CMD. Also I changed read wait and write wait to 3 clock cycles in my DM9000A component (it's related to 100MHz clock for NIOS). Best, madness --- Quote End --- Is it true that regardless of the actual PHY chip, the mdio interface is common, and the device specific initialization is done in software? If so, couldn't an existing built-in qsys component (ex. LAN91C111) be instantiated, but registers initialized for the DM9000A? EDIT: Since these chips have MACs built-in to them, why is another MAC (Altera's TSE) added into the system design... how does that even work?
