11 years agoplatform_get_resource fails
Added a custom device driver to GSRD 14.1
The IP is contained in sopc0: hps_0_bridges: bridge@0xc0000000 of_match_device - is successful - Looking in my: /proc/device-tree/sopc@0/bridge@0xc0000000/serial@0x100040000 When I do # ] hexdump -C 'compatible' I can see my entries that match with the of_match [] of the device driver When I do# ] hexdum -C 'reg' I see the values in my dev entry BUT, the platform_get_resource fails.3 Replies
--- Quote Start --- Added a custom device driver to GSRD 14.1 The IP is contained in sopc0: hps_0_bridges: bridge@0xc0000000 of_match_device - is successful - Looking in my: /proc/device-tree/sopc@0/bridge@0xc0000000/serial@0x100040000 When I do # ] hexdump -C 'compatible' I can see my entries that match with the of_match [] of the device driver When I do# ] hexdum -C 'reg' I see the values in my dev entry BUT, the platform_get_resource fails. --- Quote End --- I had a line missing in my .dts file so I generated another .dtb file and now the driver loads. STILL HAVE A PROBELM - when I use the driver I should see activity on a couple of the Cyclone V Dev kit board HSMC - but the lines aren't toggling. So - WHAT AM I MISSING? I have: 1. generated the .dtb, .rbf and added them to the microSD card. I have cross compiled my device driver and put it on the microSD card and simply done an "insmod myDriver.ko" - I saw that maybe I needed a new preloader image so I created a new on of those. - Altera_Forum
REALLY NEED SOME HELP:
1. We put our IP on the FPGA-HPS bridge that the leds are on. 2. Got/generated all the files via instructions - .rbf, .dtb (and I wasn't sure so did do the preloader-mkpimage.bin) I did have to generate a new device tree 2b. I had to update the zImage because the version magic numbers did not match -- when I did this the led-gpio driver gives the message: platform leds.1: Driver leds-gpio request probe deferral -- why? 3. I DID NOT add the driver to the kernel but just cross compiled it and put it on the sd card to manually insert. When I insert the device driver - I get an error with the: of_address_to_resource static int touchscreen_drv_probe( struct platform_dev *op) { int rc = 0; struct device_node *node = op->dev.of_node; struct resource res; // the of_match_device works --- rc = (of_address_to_resource( &op->dev.of_node, 0, &res); if (rc) { //fail } } Where could the disconnect be? - Altera_Forum
SOLVED -- used "platform_get_resource" and all is well. Not sure why the "of_address_to _resource" did not work but my device driver works fine.
