11 years agoplatform_get_resource fails
Added a custom device driver to GSRD 14.1 The IP is contained in sopc0: hps_0_bridges: bridge@0xc0000000 of_match_device - is successful - Looking in my: /proc/device-tree/sopc@0/bridge@0xc0...
11 years agoREALLY NEED SOME HELP:
1. We put our IP on the FPGA-HPS bridge that the leds are on. 2. Got/generated all the files via instructions - .rbf, .dtb (and I wasn't sure so did do the preloader-mkpimage.bin) I did have to generate a new device tree 2b. I had to update the zImage because the version magic numbers did not match -- when I did this the led-gpio driver gives the message: platform leds.1: Driver leds-gpio request probe deferral -- why? 3. I DID NOT add the driver to the kernel but just cross compiled it and put it on the sd card to manually insert. When I insert the device driver - I get an error with the: of_address_to_resource static int touchscreen_drv_probe( struct platform_dev *op) { int rc = 0; struct device_node *node = op->dev.of_node; struct resource res; // the of_match_device works --- rc = (of_address_to_resource( &op->dev.of_node, 0, &res); if (rc) { //fail } } Where could the disconnect be?
