16 years agoPIO set and clear bits
Hi! I am using a Nios II in my Cyclone II FPGA. I configured the Nios with a 18bit output-PIO. When i use the macro IOWR_ALTERA_AVALON_PIO_DATA() i can easily turn my leds on and off. Looking ...
16 years agoI never used this feature, anyway you can check system.h file. I think you should have this define: # define PIO_0_BIT_MODIFYING_OUTPUT_REGISTER 1
It would be 0 if individual set/clear is not enabled. Enabling individual set/clear in sopc builder, generates two extra pio registers at offset 4 and 5. You'll find complete (and more reliable than mine...) information in Nios reference handbook, vol 5, chapter 9 http://www.altera.com/literature/hb/nios2/n2cpu_nii51007.pdf Cris
