21 years ago
PCI/mPCI/cardbus device
I plan to use my Nios2 to connect to an external chipset. I have different choices for the interface : PCI, mPCI or cardbus. Can someone tell me what interface is the easiest to implement, I mean :
- are there opencores implementation for the hardware part ? How expensive is the licence if not in opensource ?
- does uCLinux support all these bus types ?
- how many pins are used by these busses ? (generally 32 for data, but what about the other control signals ?)
Thanks for helping.
pod
    Hi pod,
    I'm not sure whay you're asking here. But PCI, mini PCI, Cardbus are basically
    all the same.
    It can vary quite significantly. I've seen numbers anywhere from
    3000 to 12,000 USD ... plus or minus royalties.
    For standard 32-bit PCI:
    32 - Address/Data
    4 - Command/Byte Enable
    13 - Control
    1 - Clock
    I don't know what signal addition/removal (if any) for CardBus or mini PCI.
    Although, I've been told that mini PCI is identical to 32-bit PCI WRT the
    functional signals.
    --Scott
    Thanks a lot, Scott, it is exactly what I wanted to hear :-)
    pod
