21 years agoPCI/mPCI/cardbus device
Hello, I plan to use my Nios2 to connect to an external chipset. I have different choices for the interface : PCI, mPCI or cardbus. Can someone tell me what interface is the easiest to impleme...
21 years agoHi pod,
> - are there opencores implementation for the hardware part ? I'm not sure whay you're asking here. But PCI, mini PCI, Cardbus are basically all the same. > How expensive is the licence if not in opensource ? It can vary quite significantly. I've seen numbers anywhere from 3000 to 12,000 USD ... plus or minus royalties. > - how many pins are used by these busses ? > (generally 32 for data, but what about the other control signals ?) For standard 32-bit PCI: ------------------------------ 32 - Address/Data 4 - Command/Byte Enable 13 - Control 1 - Clock I don't know what signal addition/removal (if any) for CardBus or mini PCI. Although, I've been told that mini PCI is identical to 32-bit PCI WRT the functional signals. Regards, --Scott
