20 years agoOsip2 on uClinux
I am experiencing a problem, trying to use Osip under uClinux/niosII
When running the following code the whole system locks up... Is there anybody here with some Osip/Osip2 experience? # include <sys/time.h># include <osip2/osip.h> int main(void) { int i; osip_t *osip; i=osip_init(&osip); if (i!=0) return -1; } Might be a thread or semaphore problem, i just don't know where to start looking Any sugestions? regards Mikkel Kidmose5 Replies
I remember having the same problem -- it had something to do with tracing or gperf or something like that-- but it has been awhile. When you configure, try disabling the (initially) unnecessary features, then go from there. E.g.: --enable-static --disable-shared --disable-trace --disable-debug --disable-gperf Also, make sure your include paths are properly set so you don't build against the wrong headers: e.g. $ export CPPFLAGS "-I<whatever>" Regards, --Scott - Altera_Forum
Thx for the help.
I found the problem but not the solution yet.... when i make the executable the osip library isnt linked in to it statically so the osip_init is unknown. Tried adding -static to LDFLAGS but that does not help any ideas? - Altera_Forum
Remove all of your osip libraries and reconfigure ... make sure you --disable-shared --enable-static, make/install again, then rebuild your application. Regards, --Scott - Altera_Forum
thx Scott
But the solution was even simpler i had commented out my osip2 lib in rules.mak by accident... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif So now my Osip2 works.... And i have moved on to eXosip2 the init has the same problem... but it is beeing linked i am stepping thru the exosip_init() but havent found the problem yet... i configured it with: --host=nios2-elf --enable-static --disable-shared --disable-gperf --disable-libtool-lock --disable-debug --disable-josua --disable-glib --disable-glibtest --enable-pthread --enable-sysv --enable-semaphore --silent any ideas regards Mikkel - Altera_Forum
Hi Mikkel,
> had commented out my osip2 lib in rules.mak by accident... I hate it when that happens! ;-) > So now my Osip2 works.... Great! > And i have moved on to eXosip2 Sorry, can't help here. I looked at eXosip2 ... but the license for that is GPL rather than LGPL ... and I wasn't crazy about the architecture ... so I never bothered to dig any deeper. Let us know how you make out. Regards, --Scott
