20 years agoOsip2 on uClinux
I am experiencing a problem, trying to use Osip under uClinux/niosII When running the following code the whole system locks up... Is there anybody here with some Osip/Osip2 experience? # in...
20 years agothx Scott
But the solution was even simpler i had commented out my osip2 lib in rules.mak by accident... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif So now my Osip2 works.... And i have moved on to eXosip2 the init has the same problem... but it is beeing linked i am stepping thru the exosip_init() but havent found the problem yet... i configured it with: --host=nios2-elf --enable-static --disable-shared --disable-gperf --disable-libtool-lock --disable-debug --disable-josua --disable-glib --disable-glibtest --enable-pthread --enable-sysv --enable-semaphore --silent any ideas regards Mikkel
