15 years agoon-chip hex in SOF - problem to run
Hi guys,
I have a problem with this, hopefully somebody has similar experience. I have a quite simple nios program, just changing some values of pio to flash LEDs if the memory test (altera code) is successfull and printf messages. I run everthing without any problems if I use Run as -> Nios II HArdware in the Nios II EDS. But i need to have this software to start automatically after SOF is loaded (need to have soft in the onchip memory). So I generated onchip_mem.hex and recompiled the project in Quartus. After i had downloaded the sof to the chip I didn't see something was happening in the chip. So I've opened the nios2-terminal. And as soon as I opened the nios2-terminal the program launched - LED started to flash and the rest. I have no idea what is going on. I seems that the software is in onchip mem but why it doesn't start until i start nios terminal. I have reset of sopc builder connected to vcc. Nios reset and exception vectors are in onchip mem - can't have them in ddr2 since i'm testing it. Could somebody point me where should i look? Thanks, U.3 Replies
I assume you are using jtag-uart for stdin, stdout and stderr?
Try to select another uart in the BSP editor, it might be the jtag-uart is waiting for connection. - Altera_Forum
mcr42,
Yes, i'm able to run from on-chip mem after i removed jtag-uart from the stdin, stdout and stderr in the BSP editor settings. Thank you very much for help! But it looks strange to me. I did several designs in Quartus II 9.0 with soft running from onchip mem and I had jtag uart in STD without any problems. I can't see any difference except now i use quartus ii 91 sp2 and new nios ii environment, and i don't use a timer in my project. Is there any issues with jtag waiting for connection in the new versions of Quartus? Thanks, U. - Altera_Forum
I think u can add a epcs controller to your SOPC system, reset set to epcs controller, exception set to onchip-ram. then use flash programmer to program sof and elf to epcs...
try it...
