15 years agoon-chip hex in SOF - problem to run
Hi guys, I have a problem with this, hopefully somebody has similar experience. I have a quite simple nios program, just changing some values of pio to flash LEDs if the memory test (altera ...
15 years agoI think u can add a epcs controller to your SOPC system, reset set to epcs controller, exception set to onchip-ram. then use flash programmer to program sof and elf to epcs...
try it...
