20 years ago
Not found rc file in ~/rootfs/etc dir
hello all
I want to edit rc file before rebuild kernel that can't find rc file in ~/root/etc dir.
I don't like to excute "ifconfig" or "inetd" command every time under the uClinux.
Can i add a rc file in ~/root/etc dir?
On uClinux : ~/bin/login
I don't know uClibic login's account and "Password".
How to know my account and password ?
Because I don't login to use my uClinux OS every time . so , i want to creat it..
How to creat a account on uClinux OS?
Thanks in advance !
jay
    --- Quote Start ---
    originally posted by jay_1025@Apr 14 2006, 07:21 PM
    hello all
    i want to edit rc file before rebuild kernel that can't find rc file in ~/root/etc dir.
    i don't like to excute "ifconfig" or "inetd" command every time under the uclinux.
    can i add a rc file in ~/root/etc dir?
    on uclinux : ~/bin/login
    i don't know uclibic login's account and "password".
    how to know my account and password ?
    because i don't login to use my uclinux os every time . so , i want to creat it..
    how to creat a account on uclinux os?
    thanks in advance !
    jay
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14369)
    --- quote end ---
    --- Quote End ---
    There are many ways to add init tasks.
    you can add simple init command into etc/inittab, just like the lo init.
    you can add a line in inittab to run etc/rc .
    you can uncomment the line contains /etc/init.d/rcS in inittab .
    then ~/rootfs/etc/init.d/rcS will be executed during linux init.
    the default rcS will run each Sxxxxxx task.
    the account and passwd file are etc/passwd and etc/shadow .
    the simple inittab from ~/download, does not use login, it call /bin/sh directly.
    Hi hippo
    I have edit "inittab" file in ~/rootfs/etc and recompile kernel .
    But not update the initramfs....
    compile kernel info:
    perl -I/home/jay/linux-2.6.16.1/arch/nios2nommu/scripts /home/jay/linux-2.6.16.1/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu_0 sdram_0 cfi_flash_0 < nios_0.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39; UPD include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
    CHK include/linux/version.h
    CHK include/linux/compile.h
    CHK usr/initramfs_list
    Kernel: arch/nios2nommu/boot/zImage is ready
    I don&#39;t see the "GPIO" and "GZIP" in compile messages and not find "initramfs_list" file in ~/rootfs/usr/ dir.
    THx
    hi hippo
    This is booting message:
    uClinux/Nios II
    Altera Nios II support © 2004 Microtronix Datacom Ltd.
    setup_arch: No persistant network settings signature at 008F0000
    Built 1 zonelists
    Kernel command line:
    PID hash table entries: 64 (order: 6, 1024 bytes)
    Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
    Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
    Memory available: 6072k/8192k RAM, 0k/0k ROM (1402k kernel code, 623k data
    Mount-cache hash table entries: 512
    NET: Registered protocol family 16
    io scheduler noop registered
    io scheduler deadline registered (default)
    Serial: JTAG UART driver $Revision: 1.4 $
    ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart
    dmfe_probe:eth0, 50000 Khz Nios
    <DM9000> eth0 I/O: 80900090, VID: 90000a46
    ADDR: 00:07:ed:00:00:00
    dmfe_probe:eth1, 50000 Khz Nios
    NET: Registered protocol family 2
    IP route cache hash table entries: 128 (order: -3, 512 bytes)
    TCP established hash table entries: 512 (order: -1, 2048 bytes)
    TCP bind hash table entries: 512 (order: -1, 2048 bytes)
    TCP: Hash tables configured (established 512 bind 512)
    TCP reno registered
    TCP bic registered
    NET: Registered protocol family 10
    IPv6 over IPv4 tunneling driver
    NET: Registered protocol family 17
    Freeing unused kernel memory: 508k freed (0x16e000 - 0x1ec000)
    init started: BusyBox v1.1.1-pre0 (2006.04.14-14:34+0000) multi-call bina
    Bummer, could not run &#39;/bin/ifconfig&#39;: No such file or directory
    BusyBox v1.1.1-pre0 (2006.04.14-14:34+0000) Built-in shell (msh)
    Enter &#39;help&#39; for a list of built-in commands.
    # ps
    PID Uid VmSize Stat Command
    1 root DW init
    2 root SWN [ksoftirqd/0]
    3 root SW< [events/0]
    4 root SW< [khelper]
    5 root SW< [kthread]
    6 root SW< [kblockd/0]
    7 root SW [pdflush]
    8 root SW [pdflush]
    10 root SW< [aio/0]
    9 root SW [kswapd0]
    22 root Z [inetd]
    25 root SW /bin/boa
    32 root SW init
    33 root SW /bin/sh
    34 root RW ps
    I have add "/sbin/ifconfig eth0 xxx.xxx.xxx.xxx" line in ~/rootfs/etc/inittab file and rebuild kernel.
    Why not to update the kernel?........... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
    Thanks in advance !
    jay
    --- Quote Start ---
    originally posted by jay_1025@Apr 15 2006, 01:19 AM
    hi hippo
    i have edit "inittab" file in ~/rootfs/etc and recompile kernel .
    but not update the initramfs....
    perl -i/home/jay/linux-2.6.16.1/arch/nios2nommu/scripts /home/jay/linux-2.6.16.1/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu_0 sdram_0 cfi_flash_0 < nios_0.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39; upd include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
    chk include/linux/version.h
    chk include/linux/compile.h
    chk usr/initramfs_list
    kernel: arch/nios2nommu/boot/zimage is ready
    i don&#39;t see the "gpio" and "gzip" in compile messages and not find "initramfs_list" file in ~/rootfs/usr/ dir.
    thx
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14384)
    --- quote end ---
    --- Quote End ---
    the file is in kernel dir, ~/linux-2.6.x/usr/initramfs_list
