20 years agoNot found rc file in ~/rootfs/etc dir
hello all I want to edit rc file before rebuild kernel that can't find rc file in ~/root/etc dir. I don't like to excute "ifconfig" or "inetd" command every time under the uClinux. ...
20 years agohi hippo
This is booting message: uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. setup_arch: No persistant network settings signature at 008F0000 Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6072k/8192k RAM, 0k/0k ROM (1402k kernel code, 623k data Mount-cache hash table entries: 512 NET: Registered protocol family 16 io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart dmfe_probe:eth0, 50000 Khz Nios <DM9000> eth0 I/O: 80900090, VID: 90000a46 ADDR: 00:07:ed:00:00:00 dmfe_probe:eth1, 50000 Khz Nios NET: Registered protocol family 2 IP route cache hash table entries: 128 (order: -3, 512 bytes) TCP established hash table entries: 512 (order: -1, 2048 bytes) TCP bind hash table entries: 512 (order: -1, 2048 bytes) TCP: Hash tables configured (established 512 bind 512) TCP reno registered TCP bic registered NET: Registered protocol family 1 NET: Registered protocol family 10 IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 Freeing unused kernel memory: 508k freed (0x16e000 - 0x1ec000) init started: BusyBox v1.1.1-pre0 (2006.04.14-14:34+0000) multi-call bina Bummer, could not run '/bin/ifconfig': No such file or directory BusyBox v1.1.1-pre0 (2006.04.14-14:34+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands. # ps PID Uid VmSize Stat Command 1 root DW init 2 root SWN [ksoftirqd/0] 3 root SW< [events/0] 4 root SW< [khelper] 5 root SW< [kthread] 6 root SW< [kblockd/0] 7 root SW [pdflush] 8 root SW [pdflush] 10 root SW< [aio/0] 9 root SW [kswapd0] 22 root Z [inetd] 25 root SW /bin/boa 32 root SW init 33 root SW /bin/sh 34 root RW ps I have add "/sbin/ifconfig eth0 xxx.xxx.xxx.xxx" line in ~/rootfs/etc/inittab file and rebuild kernel. Why not to update the kernel?........... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Thanks in advance ! jay
