12 years agoNoobie Question on how to find/build a missing .elf file
Hello Friends, I'm adding my .sof file to the QuartusII programmer and the following message pops up. Does anyone know what the following message means? ' xxxxx.sof contains one or time limited megafunctions that support the OpenCore Plus Feature that will not work after the hardware evaluation time expires?' Don
Hi there,
That means that you either do not have a licensed Quartus (e.g. Web Edition) or that you do use an unlicensed megafunction in your Quartus and or SOPC/QSYS-Builder. But you've asked about an elf in the topic. Are you still interested in building an elf? - Altera_Forum
Hi dtelrest,
I like your profile image, "we have cookies". Haha. Ah, I should get a license then; I have the Web Edition. I was wondering if this could be the reason that I can't make the needed .elf file. I'll give you some background on what a noobie like me is doing. I'm following a tutorial for the DE0 Nano and I'm pretty close to finishing the instructions for the NIOSii tutorial in the DE0 NANO USER MANUEL at http://www.altera.com/education/univ/materials/boards/de0-nano/unv-de0-nano-board.html?gsa_pos=1&wt.oss_r=1&wt.oss=de0 nano (http://www.altera.com/education/univ/materials/boards/de0-nano/unv-de0-nano-board.html?gsa_pos=1&wt.oss_r=1&wt.oss=de0 nano) I get to the step where I build the hello world project. During building, I get the following message in the console window: 'No rule to make target `Info/My', needed by `Designs/myfirst_niosii/DE0_NANO_SOPC.ptf/Debug/system_description/../obj/generated_app.mk-t'. Stop. Build completed in 1.903 seconds' Could a web edition of Niosii or unlicensed macrofunction from a tutorial be the reason why I can't build and generate the .elf? Or does the error message above mean that I'm missing something, like making a target. Friendly Noob, Don - Altera_Forum
Hi Don,
thanks. This sounds a lot like a linker error. For Nios C and Assembler Development you do not need a license, just for generating the sof in Quartus. Can you get me a link where to find the sample project, hello world. - Altera_Forum
dtelrest,
The instructions are in the DE0 user manuel found on the Terasic website http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&ved=0cc4qfjaa&url=http%3a%2f%2fwww.terasic.com.tw%2fcgi-bin%2fpage%2farchive_download.pl%3flanguage%3denglish%26no%3d364%26fid%3d0c266381d75ef92a8291c5bbdd5b07eb&ei=9stauvnrg4mo9gtooodacg&usg=afqjcnedamlt03srgwei1jtjsm2bdnz41g&bvm=bv.53899372,d.ewu (http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&ved=0cc4qfjaa&url=http%3a%2f%2fwww.terasic.com.tw%2fcgi-bin%2fpage%2farchive_download.pl%3flanguage%3denglish%26no%3d364%26fid%3d0c266381d75ef92a8291c5bbdd5b07eb&ei=9stauvnrg4mo9gtooodacg&usg=afqjcnedamlt03srgwei1jtjsm2bdnz41g&bvm=bv.53899372,d.ewu). The NIOS ii hello world file simply says the following, # include <stdio.h> int main() { printf("Hello from Nios II!\n"); return 0; } The hello world file came with my download of NIOS ii 10.1. Don - Altera_Forum
Hi there,
i see that6 you do have a dot in your Path, myfirst_niosii/DE0_NANO_SOPC.ptf/Debug/ that may be the problem. Did you generate and build your BSP, using the sopcinfo file, in your NIOS environment?
