12 years agoNoobie Question on how to find/build a missing .elf file
Hello Friends, I'm adding my .sof file to the QuartusII programmer and the following message pops up. Does anyone know what the following message means? ' xxxxx.sof contains one or time...
12 years agoHi there,
i see that6 you do have a dot in your Path, myfirst_niosii/DE0_NANO_SOPC.ptf/Debug/ that may be the problem. Did you generate and build your BSP, using the sopcinfo file, in your NIOS environment?
