NiosV
riscv-none-embed-objcopy is in your reply dated 20th June.
Once again, I repeat, BSP editor is only available in Quartus Pro and Quartus Pro doesnt support MAX10!!
Nios V isnt properly supported it seems - if you want me to migrate from Nios2 to NiosV then Intel need to sort the tools out.
Here is the answer to one issue..
https://www.intel.com/content/www/us/en/support/programmable/articles/000092029.html?wapkw=riscv32-unknown-elf-objcopy
Still an answer to this..
One more thing:
My Nios2 had use of Exception Vector which was enabled in the NiosII IP within Platform designer.
For Nios V it must be set with the Nios V command shell because only Quartus Pro has BSP editor in Platform Designer and Quartus Pro doesnt support MAX10.!
Any advice how I do that with the niosv-bsp command?
