NiosV
Hi
For the NiosV they make the exception vector editable in the BSP Editor.
You are able to change the exception vector in the BSP Editor under the BSP linker script.
Which doc you referring to that uses the riscv-none-embed-objcopy ?
Jingyang, Teh
riscv-none-embed-objcopy is in your reply dated 20th June.
Once again, I repeat, BSP editor is only available in Quartus Pro and Quartus Pro doesnt support MAX10!!
Nios V isnt properly supported it seems - if you want me to migrate from Nios2 to NiosV then Intel need to sort the tools out.
- NGord2 years ago
Here is the answer to one issue..
https://www.intel.com/content/www/us/en/support/programmable/articles/000092029.html?wapkw=riscv32-unknown-elf-objcopyStill an answer to this..
One more thing:
My Nios2 had use of Exception Vector which was enabled in the NiosII IP within Platform designer.
For Nios V it must be set with the Nios V command shell because only Quartus Pro has BSP editor in Platform Designer and Quartus Pro doesnt support MAX10.!
Any advice how I do that with the niosv-bsp command?
