NGord
2 years agoNiosV
Hi I am in the process of converting a MAX10 Nios2 design to a MAX10 NiosV. It boots from Flash loaded into DDR All is good with the compiling apart from I need to convert the elf file to a hex fi...
NGord
2 years agoI dont think I should have "--epcs" mode set for QSPI?
if I remove that then I can add "--base" and "--reset".
That only leaves "--out-data-width=8" - I take it I dont need that for QSPI either
Also "-I elf32-littlenios2" and "-O hex" are superfluous for elf2flash I take it.
