- tehjingy_Altera
Dear Customer,
Since no further clarification is needed on this thread, it will be transitioned to community support for further help on doubts in this thread.
Please login to the Altera Community Forum and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you for the questions and as always pleasure having you here.
Best Wishes
tehjingy
- tehjingy_Altera
- LiangYuG_Altera
Hi prashant_gohel,
Can you try to modify the alt_sys_init.c?
Our team found that the current auto-generated initialization sequence is causing the JTAG UART fast driver to malfunction.
Current (Failing) - Nios V processor is initialized last.void alt_sys_init( void ) { ALTERA_AVALON_JTAG_UART_INIT (JTAG_UART, jtag_uart); INTEL_NIOSV_M_INIT (NIOS, nios); }
Modified (Passing) - Nios V processor is initialized first.void alt_sys_init( void ) { INTEL_NIOSV_M_INIT (NIOS, nios); ALTERA_AVALON_JTAG_UART_INIT (JTAG_UART, jtag_uart); }We believe that the JTAG UART initialization have some dependency on Nios V processor initialization.
As such, Nios V processor should be the first to initialize.
Liang Yu - BoonBengT_Altera
Moderator
Hi @prashant_gohel,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope your doubts have been clarified.
Best Wishes
BB
- EstebanV_Altera
Please confirm both setings pointed out by me and @dim1
In the BSP should appear as: altera_avalon_jtag_uart_driver.enable_small_driver = false and/or altera_avalon_jtag_uart_driver.enable_jtag_uart_ignore_fifo_full_error = true
~E.V.
- dim1
When you generate BSP, go to the JUART Driver settings - there is an option to allow the driver to ignore when the output FIFO is full. Enable that option and it will not wait for somebody to read the output.
- EstebanV_Altera
Could you please verify what is written here?
"fast" version of the driver shouldn't be blocking execution.
~E.V.
- EstebanV_Altera
This is not usual behavior, the default shouldn't behave like this. Are you having prints into the terminal? If you remove such prints the programs continues?
Which Quartus version are you using? Which NIOSV version (G,C,M)?
Please provide as much details as possible so I can reproduce
~E.V.
- prashant_gohel
Hi Esteban,
I am using Quartus 25.1 with NIOSV version M.
When the terminal is open, everything works fine, but if I close the terminal, the NIOSV gets stuck. Our requirement is that the NIOSV should run normally without needing the terminal to be open.
