prashant_gohel
1 year agoNIOSV firmware stuck when juart-terminal is not open for the print messasges.
Hi, I am facing an issue where the NIOSV firmware gets stuck if the JUART terminal is not open for printing messages. Once I open the JUART terminal, everything works fine. Is there any way or BSP ...
dim1
1 year agoWhen you generate BSP, go to the JUART Driver settings - there is an option to allow the driver to ignore when the output FIFO is full. Enable that option and it will not wait for somebody to read the output.
