ETang2
7 months agoNiosV and juart-terminal
I had a project which works fine under niosII. I upgrade all the project with niosv and all seems fine except printing values in juart-terminal. Here is the main code : #include <stdio.h> #inclu...
- 7 months ago
Summary:
- printf(%f) always prints 0, even if the variable contains valid floating-point number.
Change the On-Chip Ram size from decimal (such as 167.5KB / 167500 bytes) to binary (such as 167KiB / 171008 bytes). - Character é is printed wrongly.
Change the active code page of Windows's command prompt from 437 to 65001 (UTF-8)
ETang2
7 months agoThank you for your reply.
I think it's not a problem with rxbuffer[1] = 0x01 because the values in the debug window are good. So that seems that the memcopy were right.
As i put the first breakpoint at the first printf("SCD30\n"); the code before this brekpoint should be executed with the same time as usual and the values are good. The problem is when after this breakpoint i execute the code step by step the printf print the wrong values in juart-terminal. It seems also that there is print problem as the accentuated character "é for example" are not printed correctly.
Eric
