NiosV µC/OS-II
I try to design a NiosV program with TCP/IP based on this example design:
Arria® 10 FPGA – Simple Socket Server for the Nios® V/m Processor Design Example
I understand that uC-TCP-IP library needs µC/OS-II but this option is not available in bsp editor GUI (only hal and freertos are available). When I try to execute the command from the project README, I have the following error :
$ niosv-bsp -c sw/bsp/settings.bsp -qpf=hw/top.qpf -qsys=hw/sys.qsys --type=ucosii --cmd="enable_sw_package uc_tcp_ip" ...
2026.03.11.18:36:31 Warning: Environment variable SOPC_KIT_NIOS2 not set
2026.03.11.18:36:38 Info: Searching for BSP components with category: os_software_element
2026.03.11.18:36:41 Error: BSP type "ucosii" is not valid. Valid types are:
* freertos
* halI'm using Quartus Version 23.4.0 Build 79 11/22/2023 Patches 0.70 SC Pro Edition
Thank you for your help.
- AvinashTh_Altera
Glad to know the Quartus 25.1.0 resolved the issue. The other issue you reported seams like installation issue for missing package. But i have referred this issue to internal team to get proper response. We will get back to you soon.
- AvinashTh_Altera
uCOSII is supported for Nios V core.
Can you please try latest Quartus release and use the example design from this location?
Let me know
- antoineb
Ok, this is working using Quartus Version 25.1.0 Build 129 03/26/2025 Patches 0.36 SC Pro Edition.
Does it mean I have a problem with the Quartus 23 installation?
I also have this message many times during compilation:
/usr/bin/cmake: /home/intelFPGA_pro/25.1/quartus/linux64/libcurl.so.4: no version information available (required by /usr/bin/cmake)Thanks
- tehjingy_Altera
Hi antoineb
Did you run the cmake from the niosv-shell?
Could you please try running the generation of the cmake files and the make from the niosv-shell.
