16 years agoniosnommu in layout directori
Hi
i have just installed to build Nios2 uClinux. branch "test-nios2" , per 20090929 . the make menuconfig -> vendor Altera -> product : there is only one option: nios2 , there is not niosnommu option Its correct? Thanks4 Replies
At the moment the MMU enabled and the MMU-less tool chains are different distributions. AFAIK this will change soon, and both flavors will be provided in a single distribution.
Thus right now you would need to install the MME-less tool chain to do NIOS-nommu. See the Wiki for details. -Michael - Altera_Forum
Thanks ,
i will remove 20090909 flavor and install 20090730 - Altera_Forum
There is no need to reinstall. You can check out the branches for nommu. You will select nios2 in uClinux-dist, which means nios2nommu.
cd linux-2.6 git checkout test-nios2 cd uClinux-dist git checkout test-nios2 - Hippo - Altera_Forum
I did it. Read the first message.. so why the product Altera option is not niosnommu?
