16 years agoniosnommu in layout directori
Hi i have just installed to build Nios2 uClinux. branch "test-nios2" , per 20090929 . the make menuconfig -> vendor Altera -> product : there is only one option: nios2 , there is not niosnom...
16 years agoThere is no need to reinstall. You can check out the branches for nommu. You will select nios2 in uClinux-dist, which means nios2nommu.
cd linux-2.6 git checkout test-nios2 cd uClinux-dist git checkout test-nios2 - Hippo
