13 years agoNIOSII download problem
HI
when I download my project , it generate an error , but I have no idea what is the error ? How do I solve it? https://www.alteraforum.com/forum/attachment.php?attachmentid=76494 Replies
Hi, The error is not "Pausing target processor : not responding" because immediately after it tried again and it is OK
The error is "Assert "m_state == STATE_DEBUG" failed" in nios2oci.cpp file - Altera_Forum
--- Quote Start --- Hi, The error is not "Pausing target processor : not responding" because immediately after it tried again and it is OK The error is "Assert "m_state == STATE_DEBUG" failed" in nios2oci.cpp file --- Quote End --- Thank you for your reply , I understand the true error , but what can I do for this error? my project build and BSP build are all OK I don't understand what is causing this error? Is Hardware? Is Timing? Is Qsys's IP? Is formula? Anyone give me some advice? Thanks. ------------------------------------------------------------------------------------------------------- --- Quote Start --- Are you using a custom board, Altera dev kit or university board ? Which NIOS II tools ? Is suppose Nios II SBT from Quartus & Nios version >=10 (because I see Qsys). .... Hey, see http://www.altera.com/support/kdb/solutions/rd04012011_290.html ;-) --- Quote End --- 1. I use Bemicro SDK =>http://www.arrownac.com/solutions/bemicro-sdk/ 2.Quartus II 11.0 & Nios II 11.0 Software Build Tools for Eclipse 3.when I see the compiltion report , I find my altera_reserved_tck negative number. https://www.alteraforum.com/forum/attachment.php?attachmentid=7666 It will be affected? If yes, how to improve it? P.S I have joined the .sdc files https://www.alteraforum.com/forum/attachment.php?attachmentid=7667 - Altera_Forum
Which NIOS II tools ? Is suppose Nios II SBT from Quartus & Nios version >=10 (because I see Qsys). .... Hey, see http://www.altera.com/support/kdb/solutions/rd04012011_290.html ;-) - Altera_Forum
--- Quote Start --- Are you using a custom board, Altera dev kit or university board ? Which NIOS II tools ? Is suppose Nios II SBT from Quartus & Nios version >=10 (because I see Qsys). .... Hey, see http://www.altera.com/support/kdb/solutions/rd04012011_290.html ;-) --- Quote End --- 1.I use the Bemicro SDK =>http://www.arrownac.com/solutions/bemicro-sdk/ 2.Quartus II 11.0 & Nios II 11.0 Software Build Tools for Eclipse 3.When I see the compilation report ,I find my altera_reserved_tck is negative number https://www.alteraforum.com/forum/attachment.php?attachmentid=7662 It will be affected? If yes, how to improve it? P.S I have added .sdc file https://www.alteraforum.com/forum/attachment.php?attachmentid=7663
