19 years agonios2configtool not able to read target ptf
When running nios2configtool with the demo ptf file everything works
nios2configtool --ptf=../../examples/demo_2c35/sopc_system.ptf --cpu=cpu When running nios2configtool with the target ptf file like so (cpu called cpu_0): nios2configtool --ptf=/path_to_ptf/St_cpu.ptf --cpu=cpu_0 it says: Error loading the default hardware template 'nios2_dev_board': Package CYGPKG_HAL_NIOS2, 1 error occurred while reading the CDL data. I would really like to know what the error is that occurred. How do I find out? Can I look in a log-file somewhere? Update: I find that if I edit the file "hal_nios2.cdl" so that the section "cdl_component CYGHWR_MEMORY_LAYOUT" is commented out, the nios2configtool starts the GUI. So I am guessing the error has something to do with the memory layout. Our target contains DDR SDRAM that is not connected to the NIOS. Could this be an issue? Cheers Aksel1 Reply
--- Quote Start --- originally posted by aksel@Nov 30 2006, 11:17 PM when running nios2configtool with the demo ptf file everything worksnios2configtool --ptf=../../examples/demo_2c35/sopc_system.ptf --cpu=cpu
when running nios2configtool with the target ptf file like so (cpu called cpu_0):
nios2configtool --ptf=/path_to_ptf/st_cpu.ptf --cpu=cpu_0
it says:
error loading the default hardware template 'nios2_dev_board':
package cygpkg_hal_nios2, 1 error occurred while reading the cdl data.
i would really like to know what the error is that occurred. how do i find out? can i look in a log-file somewhere?
update:
i find that if i edit the file "hal_nios2.cdl" so that the section "cdl_component cyghwr_memory_layout" is commented out, the nios2configtool starts the gui. so i am guessing the error has something to do with the memory layout. our target contains ddr sdram that is not connected to the nios. could this be an issue?
cheers
aksel
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19713)
--- quote end ---
--- Quote End --- I have same problem. Does anyone know why?
