19 years agonios2configtool not able to read target ptf
When running nios2configtool with the demo ptf file everything works nios2configtool --ptf=../../examples/demo_2c35/sopc_system.ptf --cpu=cpu When running nios2configtool with the target p...
19 years ago --- Quote Start --- originally posted by aksel@Nov 30 2006, 11:17 PM when running nios2configtool with the demo ptf file everything works
when running nios2configtool with the target ptf file like so (cpu called cpu_0):
nios2configtool --ptf=/path_to_ptf/st_cpu.ptf --cpu=cpu_0
it says:
error loading the default hardware template 'nios2_dev_board':
package cygpkg_hal_nios2, 1 error occurred while reading the cdl data.
i would really like to know what the error is that occurred. how do i find out? can i look in a log-file somewhere?
update:
i find that if i edit the file "hal_nios2.cdl" so that the section "cdl_component cyghwr_memory_layout" is commented out, the nios2configtool starts the gui. so i am guessing the error has something to do with the memory layout. our target contains ddr sdram that is not connected to the nios. could this be an issue?
cheers
aksel
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19713)
--- quote end ---
--- Quote End --- I have same problem. Does anyone know why?
