19 years agonios2configtool lost its Output window
eCos Configuration Tool experts please help.
My eCos Configuration Tool, started with nios2configtool command, somehow lost its Output window. Toggling View->Output menu item does not help at all. Any one saw this before and knows what's wrong? Thanks, Garland3 Replies
Garland:
This happened to me. I looked in the configtool source and followed the following procedure: Run "regedt32" from "run" in the windows start menu Within HK_USERS search for "eCos Configuration Tool" Select "Window Size" Set "Output Height" to 0xce ( 206) Set "Output Width" to 0x390 (912) Hope that works for you. Graham.... - Altera_Forum
Worked like a charm. Thank you, Graham!
Garland - Altera_Forum
--- Quote Start --- originally posted by garland@Nov 10 2006, 02:42 AM worked like a charm. thank you, graham!garland
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19356)
--- quote end ---
--- Quote End --- Your welcome. Happy to give a little back.
