19 years agonios2configtool lost its Output window
eCos Configuration Tool experts please help. My eCos Configuration Tool, started with nios2configtool command, somehow lost its Output window. Toggling View->Output menu item does not help at ...
19 years agoGarland:
This happened to me. I looked in the configtool source and followed the following procedure: Run "regedt32" from "run" in the windows start menu Within HK_USERS search for "eCos Configuration Tool" Select "Window Size" Set "Output Height" to 0xce ( 206) Set "Output Width" to 0x390 (912) Hope that works for you. Graham....
