22 years agonios2-elf-gcc: not found
Hello everybody,
can somebody help me solving the following problem: When trying to build a project I'm getting the following error message: - nios2-elf-gcc: not found When executing the command "nios2-elf-gcc --help" in a bash shell I get a normal response. Regards, Digi http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif4 Replies
need some more info.
but first, sounds like a path problem. Did you install anything after NiosII and Quartus? If so, re-install Nios II - Altera_Forum
I installed software in the following order:
- Quartus 4.1 + SP1 - Nios II 1.0 - uC Linux 2.6 distrib 1.1 - Application plug-in patch + reboot between all installs. Problem occurs on Win 2000 as on Win XP. Paul - Altera_Forum
it'll be the uclinux install. Something in there trashes the Eclipse setup.
I should note that this isn't really their fault, Nios II didn't put out any guidelines for how a plugin should get installed. I'm making this short, sorry if it sounds like an alarm. It isn't meant to. This was discussed in another thread. Try installing Nios II again. I think that was the answer. - Altera_Forum
Kerri,
re-installing Nios II wasn't the solution. Starting the NIOS IDE from the SOPC Builder was the solution for my problem. Thanks for your support! Paul
