Oliver_I_Sedlacek
Contributor
2 years agoNIOS2 doesn't automatically run from external RAM, how to debug
I really need my NIOS2 to autostart and run from off chip RAM using the bootloader copy method. The trouble is that despite many readings of the handbook and multiple rebuilds of the design the code ...
tehjingy_Altera
2 years agoHi
Good news that you are able to get your code running back again.
You said that after you removed the code from the flash it is able to boot again.
Could it be that the code is overlapping with the FPGA configuration in the flash?
Have you tried the GSFI test to check if you could access the flash from jtag?
Jingyang, Teh
Oliver_I_Sedlacek
Contributor
2 years agoWhat is GSFI? Not this I guess http://bcpostfarmfoodsafety.com/haccp-certification/gsfi/
