NIOS2 doesn't automatically run from external RAM, how to debug
Hi Oliver
What i meant was, booting from the EP10CE25 flash.
After you boot from the EP10CE25 flash, try attaching the debugger only without flashing the image.
Unselecting the load image option in the screenshot below:
After only attaching the debugger try looking at the address 0x1 000 000.
See whether the values are the same when loading it using the debugger.
If it is not the same that means the flash could not be read by the bootloader.
In this case, you could try test reading or writing the flash separately if it is working properly.
Jingyang, Teh
Jingyang, Teh
- Oliver_I_Sedlacek2 years ago
Contributor
Sounds daft but despite looking I haven't discovered how to just attach the debugger. What's the process?
I'm out of office for a week so please don't expect my next message before then, and please don't close the case.
