Oliver_I_Sedlacek
Contributor
2 years agoNIOS2 doesn't automatically run from external RAM, how to debug
I really need my NIOS2 to autostart and run from off chip RAM using the bootloader copy method. The trouble is that despite many readings of the handbook and multiple rebuilds of the design the code ...
Oliver_I_Sedlacek
Contributor
2 years agoJingyang, yes I've used that guide for the boot copier.
1. The EMIF must be correct because the external RAM works fine. When the debugger runs the code everything works.
2. This is the most suspect area. I've read the documentation and my question is "how do I check that the vectors are correct?". What does 'correct' look like?
3. Same as point 2, what does 'correct' look like? I think the linker memory areas must be correct, see point 1.
Oliver
Oliver_I_Sedlacek
Contributor
2 years agoKeeping this alive, I really need a solution.
