NIOS2 doesn't automatically run from external RAM, how to debug
Hi Oliver
Could you share what issue that you are facing currently?
Have you managed to see the user guide on the boot copier?
I would check a few points.
- The setting in the EMIF controller, whether it is according to the board RAM.
- In the NiosII the vectors are selected to point to the EMIF.
- In the BSP linker have you selected correctly.
Jingyang, Teh
- Oliver_I_Sedlacek2 years ago
Contributor
Jingyang, yes I've used that guide for the boot copier.
1. The EMIF must be correct because the external RAM works fine. When the debugger runs the code everything works.
2. This is the most suspect area. I've read the documentation and my question is "how do I check that the vectors are correct?". What does 'correct' look like?
3. Same as point 2, what does 'correct' look like? I think the linker memory areas must be correct, see point 1.
Oliver
Contributor
Keeping this alive, I really need a solution.
Contributor
Any news. I know that if there's no activity then this will get closed even if I haven't got an answer.
Oliver
