pp123's avatar
pp123
3 months ago
NIOS V/m dbg_reset_out signal (Q25.1 Std, MAX10)
I have a problem with loading elf file.
Signal dbg_reset_out (used for resetting HDL components) is inactive (low) when I'm using "niosv-download -r -g exeFile.elf" command (Q25.1 Std, v25.2.1 Ashling GDB Server, Linux OS, MAX10 device, NIOS V variant m).
The same command for Q24.1 Std (previous version of Ashling GDB Server, the same OS and PC) works.
For me temporary solution is using additional option -o (OpenOCD instead of Ashling® RiscFree GDB Server). Is there any better solution?
  • Hi pp123​
    LiangYuG_Altera wrote:
    Please continue using OpenOCD.
    We have reported this failure to Ashling for investigation.
    Ashling have responded to us, and fix their latest Ashling GDBServer in the upcoming RiscFree IDE v26.1.1-C in Quartus Prime Pro 26.1.1. Since you are using Quartus Prime Standard, you will need to wait for the Quartus Prime Standard 26.1 for the working Ashling GDBServer.
    Liang Yu
  • pp123's avatar
    pp123
    Would you mind sharing what is the incorrect reset connection?
    Yes, of course - dbg_reset_out output connected (indirectly) with reset input. It casued probably debug module reset and (sometimes) stranged behaviour.
    "Sometimes" because using niosv-download -r -g (Q24.1 Std) at Linux PC seems worked without problems.
    This connection also worked properly in our older projects using NIOS2.
  • Thanks pp123​
    Oh ya, that is a thing to beware of.
    Resetting the debug module during "niosv-download" -r can cause un-deterministic behaviour.
    In your words, "sometimes strange behaviour".
    It is mentioned here. But we should rewrite it more explicitly for future readers.
    The NIOS2 Debug Module is different from RISC-V Debug Module.
    We aimed to make them as similar as possible at the top-level. But there are slight difference between them.
    You may refer here for migration tips from NIOS2 to NIOSV.
    (Rewrite this more explicitly too)
    Liang Yu
