Nios V/g load-writeback hazard
Summary
On a NiosV/g core, a long-latency load from an on-chip memory immediately followed by a short-latency load from the core's own TCM returns the TCM load's data in both destination registers. The first load's writeback is lost.
lw a0, 0(t0) # t0 -> On-chip memory
lw a1, 0(t1) # t1 -> DTCM (core-local) # a0 and a1 both end up holding the DTCM value
Inserting a single instruction between the two loads is enough to avoid it. Two on-chip memory loads back to back are fine, and so is the reverse order (TCM load first, then the on-chip memory load).
Minimal reproducer
Assembly:
_start:
lui t0, 0x40 # t0 = 0x00040000 on-chip memory ("input memory")
lui t1, 0x10 # t1 = 0x00010000 DTCM (core-local)
lui t2, 0xe0 # t2 = 0x000e0000 2nd on-chip memory ("output memory")
li a2, 0x47414c47 # a value distinct from the DTCM sentinel
sw a2, 0(t0) # ...store it into input_mem
nop # let the store retire. The hazard is about two
nop # adjacent *loads*; keep everything else well
nop # clear of the pair below so the test stays
nop # unambiguous.
lw a0, 0(t0) # long-latency load: on-chip memory (input memory)
lw a1, 0(t1) # short-latency load: DTCM, immediately after
sw a0, 0(t2) # output_memory[0] = result of the AXI load
sw a1, 4(t2) # output_memory[1] = result of the DTCM load
spin:
j spin
System details
NiosV/g data_manager (AXI master) is directly connected to on-chip memories and pipeline stages are limited to 3 in Platform Designer.
- otto-Q
Thanks for the answers! I/we will test with Quartus 26.1 and report back to you after that
- tehjingy_Altera
- otto-Q
Sorry, not yet, this is delayed by some days due to internal reasons
- CaroG_Altera
Hi otto-Q,
Thanks for the clear write-up and for confirming you saw this on Quartus 25.3. This looks like a known Nios V/g quirk with back-to-back loads when a longer-latency AXI/data_manager access is followed right away by a DTCM load. That one was fixed in Quartus Prime Pro 26.1.
If you get a chance, it’d be great if you could try your test again on 26.1 Pro with the same Platform Designer setup, and let us know if a0 and a1 come back with the right values. No rush — whenever it’s convenient. And if it still looks off on 26.1, just tell us and we’ll dig into it with you.In the meantime, that one-instruction gap (or DTCM-first order) you already found is a solid workaround on 25.3.
- AvinashTh_Altera
Can you please try Quartus 26.1 pro release and let me know if this issue exists? thanks
- otto-Q
This was found in Quartus 25.3 and has not been tested in newer versions
