KennyJoosen
2 years agoNios V starts in debugging mode, but not in stand-alone mode
I have migrated a working Nios II/f instance to a Nios V/g one. When launching a debugging session with RiscFree IDE and JTAG to this Nios V instance, everything operates as expected. However, when ...
- 1 year ago
I found the cause of the issue: the conversion of the ELF file to HEX file went wrong. I was using elf2flash and riscv32-unknown-elf-objcopy commands, while I should have been using the elf2hex command.
Conversion command used now:
elf2hex ${PROJECT_ELF} -o ${PROJECT_HEX} -b 0x00000000 -e 0x0007ffff -w 32 -r 4
tehjingy_Altera
1 year agoHi
Which boot method that you are using?
In general there are 3 types, Running OnChip Memory , XIP Flash Memory and boot coopier from Flash memory.
https://cdrdv2-public.intel.com/793065/ug-726952-793065.pdf
Section 4.3
