Nios-V on Cyclone IV
- 7 months ago
Hi ove
I managed to reproduce the issue on my end.
It seems like this is a valid issue on the driver side to cause the error you are facing.
A workaround currently is to limit the naming of the SystemID IP to "sysid".
Could you possible to try that and see if it solves the issue?
I already did, but still compiles with "Unknown reference to alt_avalon_sysid_qsys_test"
Hi ove
Is it possible that you could attached a full log of the command used?
I tried the steps on the environment here but could not see the error you are facing.
- Naji_Naufel_Arrow6 months ago
Hi ove,
You have to establish an Ashling RiscFree project which uses the CMake flow.
https://docs.altera.com/r/docs/726952/25.3.1/nios-v-embedded-processor-design-handbook/building-the-application-projects
Command line flow:
cmake -G "Unix Makefiles" -B software/app/build -S software/app
make -C software/app/build
Or, you can do it in the RiscFree IDE by creating a C/C++ project, selecting CMake empty file flow and pointing to the software/app folder which contains the source file.
