Nios-V on Cyclone IV
- 7 months ago
Hi ove
I managed to reproduce the issue on my end.
It seems like this is a valid issue on the driver side to cause the error you are facing.
A workaround currently is to limit the naming of the SystemID IP to "sysid".
Could you possible to try that and see if it solves the issue?
Hi Ove,
Based on you steps. can you include the altera_avalon_sysid_qsys_regs.h
WaiMun
I already did, but still compiles with "Unknown reference to alt_avalon_sysid_qsys_test"
- tehjingy_Altera7 months ago
Hi ove
Is it possible that you could attached a full log of the command used?
I tried the steps on the environment here but could not see the error you are facing.
- Naji_Naufel_Arrow6 months ago
Hi ove,
You have to establish an Ashling RiscFree project which uses the CMake flow.
https://docs.altera.com/r/docs/726952/25.3.1/nios-v-embedded-processor-design-handbook/building-the-application-projects
Command line flow:
cmake -G "Unix Makefiles" -B software/app/build -S software/app
make -C software/app/build
Or, you can do it in the RiscFree IDE by creating a C/C++ project, selecting CMake empty file flow and pointing to the software/app folder which contains the source file.
Hi ove
- ove7 months ago
Nice that worked, can now use the sysid from the firmware
Thanks for the quick assistance.
Do I need to flag this somewhere else as an bug ?
Hi ove
I have created an internal ticket(15019118996) to track this and will be fix in future release of the Quartus Tool.
Do you require further clarification on this?
