Nios V, Max10, N25Q512A QSPI, XIP
- 2 years ago
Have you tried changing the addressing mode to 4 byte addressing? The default is 3-byte and is configured through the Control Register (0x0) of the IP. It could be that the 512mb memory requires more than 3-bytes to access.
Did you set the NiosV parameter Reset Agent to QSPI Flash?
You also can refer to the link below to see if you are following the right procedure.
Thank you.
Fathulnaim
Yes, I did set my NiosV reset vector to QSPI Flash.
Thanks for the link, I think I've seen it, but I shall review it again just to make sure.
-Andy
- andy252 years ago
Ah yes, now I remember, I did follow that link, and most of it applies, except for the .jic creation. I am only putting my app.hex in flash (not my fpga bitstream), and .jic didnt seem to have any support for Max10 or my N25Q512A device.
So I tried to create a .pof instead, which is not covered in the documentation.
-Andy
