Nios V JTAG with Agilex 5
- 1 year ago
Hi @dim1,
Thanks for sharing the response from the jtagconfig, it seems that the frequency are not able being picked up/supported from the connection.
Highly suspect it could be the USB blaster I behavior causing this, and yes would suggest to use the USB Blaster II which support configurable and faster JTAG frequency.
Do let us know once you managed to found one and try it out.
Hope to hear from you soon.
Best Wishes
BB
Hi @dim1,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Did you managed to try it out with USB Blaster II
Hope your doubts have been clarified.
Best Wishes
BB
- dim11 year ago
Hello BB,
I am still trying to procure USB Blaster II. This may take some more time.
I am going to accept your response as a solution, and in case I still see the issue with USB Blaster II I will post again.
Thank you,
d.
