linhviet306
1 year agoNios V Ethernet failed on Cyclone V GT development kit
Hi, I'm currently learning to transfer data through Ethernet using Nios. Since I use Quartus Prime 22.1, the niche stack isn't there anymore, so I tried to use Nios V and uC/TCP IP base on the CVGT s...
tehjingy_Altera
1 year agoHi
I am Jingyang and will be helping out on this case.
When you mention you increased the mSGDMA to 2K are you referring to the buffer size?
When it is on listening, that means you are able to connect to it by ssh.
Try using another device (using Putty or Telnet) and connect to 192.168.1.234 with port 80.
You should be able to receive some logs from the board.
Jingyang, Teh
linhviet306
1 year agoHi Jingyang, thank you for your support!
I did try with putty and it said connection time out. I started debug and tried to ping from the board and it failed. The NetBuf_Get method failed. I noticed the Tx led is always on. So I think there maybe some error with the buffer address pointer of the mSGDMAs or TSE.
