Nios-V .elf download failure
- 1 year ago
Hi Balerion,
When you are able to download the elf using the --go command, it is likely that your setup on the board is correct alreadyThere is an update by the way. I tried the command
"niosv-download.exe app.elf --go"-> Hello Nios V World!
And you saw this error when trying to connect with RiscFree
Initializing connection ...
Cannot set the JTAG frequency, continuing with auto adjust mode
Connected to target device with IDCODE 0x2e240dd using USB-Blaster-2 (1) via JTAG at 24.00MHz.
Info : Active Harts Detected : 1
Info : Core[0] Hart[0] is in halted state
Info : [0] System architecture : RV32
Info : [0] Number of hardware breakpoints available : 1
Info : [0] Number of program buffers: 8
Info : [0] Number of data registers: 2
Info : [0] Memory access -> Program buffer
Info : [0] Memory access -> Abstract access memory
Info : [0] CSR & FP Register access -> Abstract commandsWaiting for debugger connection on port 56767.
Press 'Q' to Quit.This could be your RiscFree's setting or your host system's setting not set correctly.
Likely Root Causes
GDB Server launched by risc free failes to connect IDE cannot detect the prompt (gdb) migh due to the followinga) Firewall/antivrus is blocking the local host port access
b) IDE times out before connection is established
c) There is a mismatch in how the debug config launches
Possible Fix
a) Temporarily disable antivirus / firewall
b) Try launch RiscFree as administrator
c) Increase debugger timeout (if IDE allows)
Please let me know the result after you try the step and provide screenshot if possible.Regards,
Boon Khai
Hi Balerion,
You have two board, Cyclone-V and Arria-10, and you were saying with the same main.cpp and the same steps, loading into Cyclone-V works but not Arria-10?
You can try check with
1) Quartus programmer jtag chain by running
jtagconfig
2) check that the nios-v processor is actually present and makesure your sof file includes a nios v processor, if the bitstream doest not instantiate a nios-v core the debugger wont find any risc-v harts (hence "no hart found" error), please make sure the bitstream is programmed first
3) verify BSP and platform configuration and make sure your BSP is generated from a platform designer system that includes required peripheral eg: JTAG UART, clock and reset, memory map etc.
Boon Khai
- Balerion1 year ago
Hi BoonkhaiN,
Actually I couldn't download .elf to the both device.
For Cyclone-V board,
I used Quartus Prime 24.1 Standard version. My design is synthesized with it. Then I generated my BSP using niosv shell of Quartus 24.1 std. I used the command "niosv-bsp -c -t=hal --sopcinfo=system.sopcinfo bsp/settings.bsp" to generate the BSP then for the app, I used the command "niosv-app -a=app -b=bsp -s=app/hello.cpp". Then I import the Nios-V CmakeList project into RiscFree IDE then compiled it. However, When I try to download it to the target it gave me error as I said in the previous post. Which is,
Initializing Connection ...
Unable to setup adaptive clock.
Internal error. Couldn't halt the target timeout occured.
Error occured attempting to halt the target during discovery.
I can download .sof through Quartus Programmer. I can see the fpga in Jtag Chain. I can also open juart-teminal from console. I can see the target device and Nios-v core through RiscFree IDE Debug Configuration. However I couldn't download my .elf to the target.
For Arria-10 Board,
I used Quartus Prime 24.3 Pro version. My design is synthesized with it. Then I generated my BSP using niosv shell of Quartus 24.3 pro. I was thinking of using .sopcinfo file to generate bsp however, I read that it is discarded from currnet CLI interface commands. So that, I used the command "niosv-bsp -c -p=system.qpf -s=system.qsys -t=hal bsp/settings.bsp" to generate the BSP then for the app, I used the command "niosv-app -b=bsp -a=app -s=app/hello.cpp". Then I import the Nios-V CmakeList project into RiscFree IDE then compiled it. However, When I try to download it to the target it gave me error as I said in the previous post. Which is,
Initializing connection...
Cannot set the JTAG Frequency, continuing with auto adjust mode.
Error occured during enumeration of RISC-V harts(no hart found).*****************************************************************************
I couldn't get the problem in both case, Is there anything you suggest me to do?
Balerion
