20 years agonios terminal error
when I start up the nios terminal in nios SDK by entering the command nios_terminal, there is a message shown as "the JTAG cable you are using is not supported for NiosII system, you may experience intermittent JTAG failure with this cable. Please use a USB Blaster revision B cable and other supported cable".
what does it mean by? and what shall I do? Thank you1 Reply
--- Quote Start --- originally posted by cuimi@Jun 2 2006, 04:34 PM when i start up the nios terminal in nios sdk by entering the command nios_terminal, there is a message shown as "the jtag cable you are using is not supported for niosii system, you may experience intermittent jtag failure with this cable. please use a usb blaster revision b cable and other supported cable".what does it mean by? and what shall i do? thank you
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15789)
--- quote end ---
--- Quote End --- It means you need to buy a USB Blaster. There is a second source from www.terasic.com.tw . You should post this question on General discussion board. Not here!
