22 years ago
NIOS II/f core
I create system design based on NIOS II/s core (insrt cahe 512 bytes).
In my design programm and data memory located in SRAM (Cyc. dev board). RESET and ISR code in on_chip RAM.
My program work correctly (instr. cashe not used).
When I replace NIOS II/s to NIOS II/f core my programm start work incorrectly (not work lwip stack).
What reason for this behavior?
    The are two potential reasons why your Nios II/f fails.
    There is a known bug in the Nios II/f data cache in release 1.0 that shows up on Cyclone.
    A fix for this bug will be released in a few weeks with the Nios II 1.0.1 release.
    The bug is a rare case that only shows up in unoptimized code. So, as a quick experiment,
    make sure all your code is compiled with optimization enabled.
    The other possibility is that the data cache isn't being bypassed/flushed consistently by the software.
    The Nios II/f uses a writeback cache so if software bypasses the data cache on a store and
    then uses a normal load that reads the value from the data cache, the most-recent value
    of that address won't be returned. This is not a bug in the data cache but is a bug in the software.
    Can you tell me more about your SOPC Builder system and the software you are running?
    Quartus design: VHDL full_featured
    System libtrary: 1C20_full (altera full_featured design), single thread
    Design compiler: Quartus 4.1 SP1
    Fitter settings:
    Physical synthesis effort: NORMAL
    Perform physical synthesis for combinational logic = checked
    Perform register duplication = cheked
    Perform register retiming = cheked
    Application: catted stand alone lwIP WEB server (removed all application calls), lwipopts.h by default.
    Test task: checking PING function
    Test options:
    Linker: all memory place to ext_ram.
    Optimization(NONE):
    lib: -O0
    app: -O0
    Data cashe: 2KByte - passed
    Data cashe:
    1KByte - failed ( printf ("Application started.\n"); executed. )
    1KByte(Set compiler options for lib & app to: -O3, -faster code) - failed.
    1KByte(as prev., rwdata placed to SDRAM) - failed.
    In the main code data cashe memory dirrectly not used!!!
    int main(void)
        struct netif netif;
        struct ip_addr ipaddr, netmask, gw;
        unsigned int now, lasttime;
        int i;# if IP_REASSEMBLY
        int j;# endif
      alt_avalon_lan91c111_if* dev_list_ptr =  (alt_avalon_lan91c111_if*)alt_ethernet_device_list.next;
        printf("Example web server using Light-weight IP (LWIP)\n");
        printf("and simple RAM-based file system.\n\n");
    /* Initialize lwip */
        lwip_init();
        printf ("Setting IP address to: %d.%d.%d.%d\n", IPADDR0, IPADDR1, IPADDR2, IPADDR3);
        printf ("Setting netmask to: %d.%d.%d.%d\n", NETMASK0, NETMASK1, NETMASK2, NETMASK3);
        printf ("Setting gateway address to: %d.%d.%d.%d\n", GWADDR0, GWADDR1, GWADDR2, GWADDR3);
        IP4_ADDR(&ipaddr, IPADDR0, IPADDR1, IPADDR2, IPADDR3);
        IP4_ADDR(&netmask, NETMASK0, NETMASK1, NETMASK2, NETMASK3);
        IP4_ADDR(&gw, GWADDR0, GWADDR1, GWADDR2, GWADDR3);
       netif_add(&netif, &ipaddr, &netmask, &gw,
                                              (void*)dev_list_ptr,
                                              lan91c111if_init,
                                              ip_input);
        netif_set_default(&netif);
    /*Initialize application(s) */
     * main loop to service the Ethernet device and expire TCP timers
      lasttime = get_milliseconds();
        i=0;# if IP_REASSEMBLY
        j=0;# endif
        while(1)
      lan91c111if_service(&netif);
      now = get_milliseconds();
      if (now - lasttime > TCP_TMR_INTERVAL) {
          lasttime = now;
          tcp_tmr();
          if (++i==50) { /*etharp_tmr();*/ i=0;    }
    # if IP_REASSEMBLY
          if (++j==1000) { ip_reass_timer(); j=0; }    # endif
    Any comments?
    Don't forget to make things like this:
    volatile declerations (volatile doesn't bypass cache anymore, but it should be done still since the compiler could synthesize that out).
