21 years agoNIOS II Zip Filing System Project error
Hi everyone!!!!
I'm getting a trouble with Zip Filing System Project. I don't know why I always receive the error : "No rule to make target 'files.zip' , needed by 'altera_ro_zip_file_ok' ". Please show me the way to solve this problem. I really don't want to re-install both Quartus and NIOS II IDE. Thank you so much, Quan Nguyen1 Reply
I'm hazarding a guess, but have you configurred the file system to point to a valid zip file?
If you right click on the System Library and select Properties you come to the system library configuration page. If you press the software components button and select the Zip Read Only File system you need to check that the zip file is a genuine file.
