tato_pt's avatar
tato_pt
5 months ago
NIOS II "Verify failed" for on-chip memory 128k
Hello!
I'm using a Cyclone 10LP FPGA 10CL055YU484I7G FPGA.
I have a 11k size program for NIOS II. I have a large on chip RAM (because I have a larger program which I want to use later) of 128k. Everything compiles and links OK. But when I try to download the program I get a "Verify failed between address 0x20000 and 0x2FFFF". The 128K  memory is located 0x20000 to 0x3FFFF
If I reduce the RAM to 32K, for example, everything works great!!.
  • The initialize memory content option is turned on for the memory
  • The BOOT RAM starts at 0x00000
  • If I download a bigger program (117k), I still get the same error.
  • ProFromDover_Altera's avatar
    ProFromDover_Altera
    Can you share a screen shot of your Nios II instruction master and data master address map?  I'm interested in the "Address Map" tab in platform designer showing the full address map of the connected peripherals to each of the instruction and data masters on the Nios II.  I don't quite understand how the BOOT RAM fits into your system here.
    Are you configuring your BSP for this application that you're trying to download with the "Allow code at reset" option enabled in the BSP editor?  Or are you just trying to compile the program that would load and execute in your RAM at 0x20000?
    Can you provide a screen shot of your BSP Linker Script tap that show how the software sections are mapping into your memory regions?
    The error that you're getting basically means that the code downloader attempted to write the data from your program into the target memory and then it read it back to verify the contents and the read back does not match what it wrote in originally.  This can be caused by various hardware or BSP misconfigurations which is why I'd like to see the screen shots that I requested above.
    If you'd like to simply test your hardware configuration, you could create some test images that you can download to the target where you fill a few test files with 8K, 32K, 64K and 128K of data for instance.  That could give you confidence that your hardware is configured and working properly and point towards a BSP configuration issue.  Or it could identify that your hardware is not operating correctly.
    Here's an AI description on how to create a Random ELF file that you could use to load the Nios II memory with nios2-download:
    To create a Nios II ELF file with a specific 128KB loadable section filled with random data at address 0x20000, you need to generate the raw random binary data, link it using a custom linker script, and compile it using the Nios II toolchain.
    1. Generate the Random Data Binary
    First, create a raw binary file containing exactly 128KB of random data.
    bash
    dd if=/dev/urandom of=random_data.bin bs=1k count=128
    Use code with caution.
    2. Create the Custom Linker Script
    Create a text file named linker.ld. This script defines the target memory address and forces the random data into a loadable section.
    linker
    MEMORY
        /* Define the target memory region */
        random_mem : ORIGIN = 0x20000, LENGTH = 128K
    SECTIONS
        /* Create a loadable section named .random_section */
        .random_section :
            KEEP(*(.data))
        } > random_mem
    3. Convert the Binary to an Object File
    Use the Nios II binary utility tool to wrap your raw binary into an object file (.o). This flags the data so the linker can recognize it.
    bash
    nios2-elf-objcopy -I binary -O elf32-nios2 \
        --rename-section .data=.random_section \
        random_data.bin random_data.o
    4. Link into the Final ELF File
    Link the object file using your custom linker script to output the final ELF executable.
    bash
    nios2-elf-ld -T linker.ld random_data.o -o random_data.elf
    5. Verify the ELF File
    You can verify that the section was created correctly, has the right size, and is marked as loadable (LOAD).
    bash
    nios2-elf-objdump -h random_data.elf
    Look for .random_section in the output. It should show a size of 00020000 (128KB), a VMA/LMA of 00020000, and the flags CONTENTS, ALLOC, LOAD, DATA.
    • LiangYuG_Altera's avatar
      LiangYuG_Altera
      Hi all,
      Agree with ProFromDover_Altera​ & Naji_Naufel_Arrow​ on something to do with the Address Map.
      This successful case tells us that,
      • The 11k program downloads successfully into a 32K BOOTRAM that starts at 0x0.
      • Since the 32K memory cannot fit 117K program, such error is expected.
      This failing case tells us that,
      • The same 11k program fails to download into a 128K RAM that starts at 0x20000.
      Did you regenerate the BSP project & rebuild the 11k program, after changing the RAM size or RAM start address?
      Will you mind sharing the QSYS, BSP projects & 11k program project?
      1. 32K BOOTROM that starts at 0x0
      2. 128K RAM that starts at 0x20000
      Liang Yu
    • Naji_Naufel_Arrow's avatar
      Naji_Naufel_Arrow
      If the onchip-memory is at address 0x00000, AND both nios-II instruction_master and data_master busses are connected to it.
      The Reset Vector in the NIOS-II Vectors tab must be pointing to the onchip-memory and set to 0x00000.
      Does your BSP have anything set to 0x20000?
