13 years agoNios_II UDP Offload example Frame error
Hi all,
I'm using udp_payload_inserter part of UDP Offload example to send frame from TSE to PC. The PC application (c#) receive frame only when i'm running wireshark!!! I think that the frame does not contain FCS (frame check sequence) any of you had this problem? best regards, HH1 Reply
What makes you think that frame check sequence is the specific reason allowing Wireshark to receive the data and your regular C# application to not receive it?
It seems more likely to be one of the usual suspects like IP or port number to have been programmed incorrectly.
