19 years agoNIOS II Quick Start tutorial issue
Hi
I am getting the following in the NIOS II IDE quick start tutorial, am I doing something wrong? I tried all the steps a couple of times... ************************************************************** Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused ************************************************************** Thanks,4 Replies
I was trying to run the tutorial on 'standard' configuration from NIOS II IDE examples. I tried it with different configurations and different programs but still the same error is reported. Now I have not been able to run any program on the Altera DE2.
Please Help. Thanks, - Altera_Forum
Guys:
I got the solution. There was error in pin assignments........ - Altera_Forum
--- Quote Start --- originally posted by napster@Jan 13 2007, 12:09 AM guys:i got the solution. there was error in pin assignments........
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20545)
--- quote end ---
--- Quote End --- I Have the same problem and get the same error message, too. Can you explain me your solution step by step? What is wrong with the pin assignments? Thanx.
